baldilocks Posted January 20, 2013 Report Share Posted January 20, 2013 Lookin for a secondhand bike between Quote Link to comment Share on other sites More sharing options...
paul w Posted January 20, 2013 Report Share Posted January 20, 2013 they all had the problem. I replaced 2 on 2008 bikes. Quote Link to comment Share on other sites More sharing options...
technowaldo Posted January 20, 2013 Report Share Posted January 20, 2013 not really the end of the world if the casing is rotton as £80 fixes it . i wouldnt walk away from an otherwise good bike just for the sake of the casing Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted January 20, 2013 Report Share Posted January 20, 2013 I'm just asking for a friend. Is the state of Beta quality control really that embarassing? Quote Link to comment Share on other sites More sharing options...
paul w Posted January 21, 2013 Report Share Posted January 21, 2013 build quality and trials bikes don't really go hand in hand unless you get a 4rt, that should set hares running! Quote Link to comment Share on other sites More sharing options...
naichuff Posted January 21, 2013 Report Share Posted January 21, 2013 (edited) I have an 03 200 Rev 3 with alloy case with no problems But my friend has a later 08 with a magnesium case and it leaked under the waterpump hose There is a coolant just designed to prevent this problem Edited January 21, 2013 by naichuff Quote Link to comment Share on other sites More sharing options...
pindie Posted January 21, 2013 Report Share Posted January 21, 2013 Use gloss paint as coolant. That way it will seal up any leaks as you go. I am joking of course! Quote Link to comment Share on other sites More sharing options...
neils on wheels Posted January 21, 2013 Report Share Posted January 21, 2013 Lookin for a secondhand bike between £1500 and £2000 for a friend. Havent decided what yet but can anyone recall which is the first year rev 3 not too have the corrosion problem caused by the coolant ? I think the question may need to be inverted; i.e. what is the latest year of Rev3 not to have this problem. I too replaced a case on a 2008 bike which was the last of the Rev3s before the Evo was introduced in 2009. Quote Link to comment Share on other sites More sharing options...
naichuff Posted January 21, 2013 Report Share Posted January 21, 2013 He repaired the case with a metal bond stuff The other fix was to use the early alloy case if they are still available Quote Link to comment Share on other sites More sharing options...
tltel Posted January 22, 2013 Report Share Posted January 22, 2013 Betas with rotten cases? This is a new one on me, what with stators packing up cracking frames, kickstart on the wrong side, I would buy a Gas Gas TLTEL Quote Link to comment Share on other sites More sharing options...
dan williams Posted January 22, 2013 Report Share Posted January 22, 2013 Use propylene glycol based premixed coolant like Engine Ice or Silcolene Pro-Cool and there is no problem. Tap water is the devil's coolant! I'm still curious where the magnesium that is being leetched away from the cases is being deposited. Quote Link to comment Share on other sites More sharing options...
pindie Posted January 23, 2013 Report Share Posted January 23, 2013 Betas with rotten cases? This is a new one on me, what with stators packing up cracking frames, kickstart on the wrong side, I would buy a Gas Gas TLTEL I think you'll find Beta puts the kick start on the proper side as it's better. Beta=Better! Quote Link to comment Share on other sites More sharing options...
