mowen123 Posted January 21, 2013 Report Share Posted January 21, 2013 hi all i have a 2010 sherco 300 cabestany when its cold it start ok will run spot on alday but when you go to start it when its hot it backfires,it always start up after a bang just wanted to know if i can stop it doing it . Quote Link to comment Share on other sites More sharing options...
zerorev3rev4 Posted January 21, 2013 Report Share Posted January 21, 2013 try retarding the timing if possible Quote Link to comment Share on other sites More sharing options...
steve_earle Posted January 21, 2013 Report Share Posted January 21, 2013 Sounds normal for this model, A guy in our club has a 2010 cab and it does the same. I have a later 300 factory and mine does it too. They run very advanced on the timing for performance, you can retard the timing depending on your ignition type but it will soften the power a bit if you go too far. Quote Link to comment Share on other sites More sharing options...
copemech Posted January 22, 2013 Report Share Posted January 22, 2013 I believe somewhere around a 2-3mm retard on the plate will help mitagate this with little change of performance. My thoughts, Quote Link to comment Share on other sites More sharing options...
gii Posted January 22, 2013 Report Share Posted January 22, 2013 Try a new spark plug in it. Try kicking it over faster, not harder (breaks things), just faster. When it's hot. put it in gear then pull backwards against compression before you kick, it's amazing what a diffference it makes. Retard the timing as above. They don't run the same though. I like a softer motor, so a Cab would be a waste........ Put up with it Quote Link to comment Share on other sites More sharing options...
mowen123 Posted January 23, 2013 Author Report Share Posted January 23, 2013 Sounds normal for this model, A guy in our club has a 2010 cab and it does the same. I have a later 300 factory and mine does it too. They run very advanced on the timing for performance, you can retard the timing depending on your ignition type but it will soften the power a bit if you go too far. steve it is me from waltham chase lol Quote Link to comment Share on other sites More sharing options...
steve_earle Posted January 25, 2013 Report Share Posted January 25, 2013 Hi Mark I didn't realise at first from your user name but it makes sense now. You had a good ride on Sunday, well except section 8 LOL. It's funny when people jump when our bikes backfire, just need to find out how to make mine bang louder now!! See you at the next trial mate, I'll be at the next Waterside one probably. Quote Link to comment Share on other sites More sharing options...
mowen123 Posted January 26, 2013 Author Report Share Posted January 26, 2013 lol i know **** that one up just didnt open it up tryed to go up it on tick over lol dont know why, think i had a funny 5 mins Quote Link to comment Share on other sites More sharing options...
