Clutch Set Up For Bultaco Sherpa 175
digger 1
On the end of the gear box shaft the clutch push rod there should be a mushroom shaped piece ( similar in shape to a valve in a four stroke) with a machined face on the end This runs on the flat roller bearing The other side of the roller runs on the adjuser screw Inside the main gear shaft there should be a push rod (lever end) then a ball then the part as above After I assemble a clutch I would pull it in and gently turn it ajusting the springs untill it runs true then wire the nut on
hi bondy just got your email many thanks for that now i know the mushroom and ball bearing is missing. I will contact buultaco uk to see if they have them, will try to get some pics together when i start putting the bike back together
