Front Axle Spacers
digger 1
Simple answer : No.
There is a flanged ("top hat") spacer inside the brake plate between it and the hub bearing, a spacer between the two bearings (inside the hub) and a further spacer on the left side between the bearing and l/h. fork slider; none between the brake plate and r/h fork slider. Tightening the wheel spindle nut on r/h. side pulls the whole wheel and brake assembly up to the r/h. fork slider.
Hope this helps.
