yorick Posted February 2, 2013 Report Share Posted February 2, 2013 Help ! I am stripping my 1987 TY250 and need a clutch holding tool so that I can undo the large clutch nut Does anybody have one that I could borrow ? Or do you know one from other bikes that will fit mine? There are plenty on Ebay for other bikes, so would be helpful to know which others will fit Many thanks in advance Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted February 2, 2013 Report Share Posted February 2, 2013 Alas poor Yorick twood help to know wherefore thou cometh from. Quote Link to comment Share on other sites More sharing options...
copemech Posted February 3, 2013 Report Share Posted February 3, 2013 Alas poor Yorick twood help to know wherefore thou cometh from. Class that is! Quote Link to comment Share on other sites More sharing options...
paul w Posted February 3, 2013 Report Share Posted February 3, 2013 if the engine is out, take the whole thing down to a car garage and get someone to spin it off with an air gun, no need for a tool. Or, i don't suppose you have tried a Yamaha dealer have you, from memory there were only 3 sizes on all yams that age anyway. Quote Link to comment Share on other sites More sharing options...
yorick Posted February 3, 2013 Author Report Share Posted February 3, 2013 Alas poor Yorick twood help to know wherefore thou cometh from. Thame, Oxfordshire Quote Link to comment Share on other sites More sharing options...
yorick Posted February 3, 2013 Author Report Share Posted February 3, 2013 if the engine is out, take the whole thing down to a car garage and get someone to spin it off with an air gun, no need for a tool.. The inner bit of the clutch spins very freely and not sure if an air gun will do the trick Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted February 3, 2013 Report Share Posted February 3, 2013 Try getting an old clutch plate and welding a stout piece of bar to it that should lock the centre so you can use an air gun on it to undo. Quote Link to comment Share on other sites More sharing options...
paul w Posted February 3, 2013 Report Share Posted February 3, 2013 Just get hold of the centre with a bit of rag, undo every time, mind you i have no fingernails left! Quote Link to comment Share on other sites More sharing options...
yorick Posted February 3, 2013 Author Report Share Posted February 3, 2013 Try getting an old clutch plate and welding a stout piece of bar to it that should lock the centre so you can use an air gun on it to undo. I had one of them as a yoof for me LC350 Quote Link to comment Share on other sites More sharing options...
tony27 Posted February 3, 2013 Report Share Posted February 3, 2013 This is what I have, works for flywheel as well http://www.tytrials.co.uk/trailandtrialsuk/prod_424514-Clutch-Flywheel-Holding-Tool.html Quote Link to comment Share on other sites More sharing options...
