rgvlc Posted February 3, 2013 Report Share Posted February 3, 2013 Hi, Just changed the seals on my 95 USD forks and would like to know what the recommended fork oil weight is. Quote Link to comment Share on other sites More sharing options...
neilnh Posted February 3, 2013 Report Share Posted February 3, 2013 as light as possible check in your local motorbike shop i believe its 5w Quote Link to comment Share on other sites More sharing options...
billyt Posted February 4, 2013 Report Share Posted February 4, 2013 Which fork leg do you want to know the viscosity of? One is compression the other rebound so one can put in different viscosity oils end each leg to achieve desired affect. Most people I know put a heavier oil in the compression side i.e. 10 > 15 weight and 5 > 10 weight in the rebound side. Hope this kelps? Quote Link to comment Share on other sites More sharing options...
