Tlr 200 Shift Problem
potgut
Hi
Its a long time since I had a look inside my TLS but have you checked the arm on the gear shaft to make sure its not bent or worn were were it locates on the selecter star.
Also Is it the clutch cover that stops the shaft from moving in(end play ) ? It could be worn.
Can't really see how it could be inside the gearbox.
TLTEL
