My Sherco 125 Leaking Coolant Out Off. Wee Hole Underneath The Coolant/water Pump Please Help
zak
Hi Zak
that "little hole" is the water pump tell-tale that indicates that the water pump seals are starting to leak.
The good news is that a little leak can go on for a while before it becomes a gusher. However you cant tell when this might be, and its quite an easy job anyway.
The job itself involves removing the clutch cover, dissasembling the pump impeller shaft assembly, Inspect the shaft for grooves / wear, replace the seals, reassemble.
It took me an hour and didnt involve any really special tools.
Dom
Zak
yes, both need draining.
There is a cheat with the gearbox oil if your really in trouble (or skint), it involves laying the bike over on its side to stop the oil flooding out when the clutch cover is removed. Careful, the tank is best removed (leakage) and you must cover the open clutch area to stop dirt getting in.
The pump seal replacement tutorial is on the Sherco or RYP website. Suggest a review, but not a bad job if you do it right. Also a bit of silecon grease on the new shaft and seals is reccomended, or just regular grease is better than nothing at all.
MC
Zak
Ham2 is referring to the need to stop the water pump impeller shaft rotating whilst undoing the impeller.
You can avoid making a special tool:-
  • Clean the shaft end then wrap it in tape / cloth to avoid the vice marking it. The impeller isnt immensly tight on the shaft (6ft/lb)
You will see what we mean in this PDF http://www.lewisport...replacement.pdf
Dom
Edited by dombush
Zak
Dom
Right then, as Dom has linked the tutorial, one item of mention. After a quick review, I found no mention of inspecting the shaft for grooving of the seals. This is a critical point of this seal replacement thing and one may have recurrent issuse if a grooved shaft is not replaced. It seems the earlier shafts were a softer material and almost allways required replacement.
Reports are that the later shafts are more robust, yet the fact there "is" a weep hole does in itself present the potential for dirt dust and water entry that may effect the shaft and seals, so once again, and in a more common sense area, this is why one may want to put a bit of lube in there on the seals, not onlt to prevent dry seals, but to deter or reject dirt and water entry to the seal lip area. Not a lot, just a bit! Do as you like and good luck with it!
