scot taco Posted February 9, 2013 Report Share Posted February 9, 2013 Does anyone know the correct float level for the stock carburetor on my 250A ? The bike runs decent,but while cleaning the carb today I noticed the floats do not sit parallel with the carb base.I,m not sure if I will mess with it or not because it runs ok. Quote Link to comment Share on other sites More sharing options...
motovita Posted February 10, 2013 Report Share Posted February 10, 2013 If you don't screw with it, you won't make it any worse. Quote Link to comment Share on other sites More sharing options...
yorick Posted February 10, 2013 Report Share Posted February 10, 2013 If it ain't broken, don't fix it Quote Link to comment Share on other sites More sharing options...
jon v8 Posted February 10, 2013 Report Share Posted February 10, 2013 If it runs OK,as said I would leave it be,but maybe measure the height and note it down for future reference.If you later change something else and have problems it might become clear why it was set like that.Dont know about you but my memory gets worse as the years go by... Quote Link to comment Share on other sites More sharing options...
scot taco Posted February 10, 2013 Author Report Share Posted February 10, 2013 Yes,my memory and eyes have been on the decline in recent years.That is a good idea,thanks Jon.Also a good call from yorick and motovita.Thanks for the replies,I think I will leave well enough alone until there is good reason to change it. Quote Link to comment Share on other sites More sharing options...
Tillerman6 Posted August 19, 2018 Report Share Posted August 19, 2018 Old thread, but could it be that since the carb body does not sit level with the ground, they had to make the float sit level with the ground and not the carb body. The fuel level might flood the carb if the float was level with the carb body since it is on an angle when it is mounted on the reed cage manifold. Quote Link to comment Share on other sites More sharing options...
