iridebikes Posted February 12, 2013 Report Share Posted February 12, 2013 hey, just got my 2011 beta evo and i wondering what the different map settings are please help me Quote Link to comment Share on other sites More sharing options...
pindie Posted February 12, 2013 Report Share Posted February 12, 2013 How do you mean? Do you mean the handlebar switch? On my old Raga gasser it was.... Rain/wet map = softer delivery and reduced throttle feel - good for mud etc. Dry/power map = crisper delivery and better power but it comes way quicker - excellent for sudden power bursts etc. Quote Link to comment Share on other sites More sharing options...
iridebikes Posted February 12, 2013 Author Report Share Posted February 12, 2013 No on the evo the switch is under the top left plastic and has a 1 or 2 on there just not sure the diffence but you maybe right so thanks anyway Quote Link to comment Share on other sites More sharing options...
pa. Posted February 12, 2013 Report Share Posted February 12, 2013 Position 1 has a softer top end. Position 2 is more aggressive in the top end. The bottom half of the mapping is the same. Quote Link to comment Share on other sites More sharing options...
wobblenorbed Posted February 13, 2013 Report Share Posted February 13, 2013 Do you switch this over with the engine on or off? And mines a gas gas so is the button pressed in for on or sticking out for on ???????????? Quote Link to comment Share on other sites More sharing options...
pa. Posted February 13, 2013 Report Share Posted February 13, 2013 Do you switch this over with the engine on or off? And mines a gas gas so is the button pressed in for on or sticking out for on ???????????? With a Beta you can switch it on the move. No idea about the Gasser's. Quote Link to comment Share on other sites More sharing options...
iridebikes Posted February 13, 2013 Author Report Share Posted February 13, 2013 Position 1 has a softer top end. Position 2 is more aggressive in the top end. The bottom half of the mapping is the same. Thanks for that Quote Link to comment Share on other sites More sharing options...
iridebikes Posted February 13, 2013 Author Report Share Posted February 13, 2013 Do you switch this over with the engine on or off? And mines a gas gas so is the button pressed in for on or sticking out for on ???????????? Think of a light swtich, when is turned off the bigger part faces the turned off bit so it almost like rejecting it so on the gas gas if the bigger bit faces the 1 side Map 2 is on or the other way round hope it helps 1 Quote Link to comment Share on other sites More sharing options...
pindie Posted February 13, 2013 Report Share Posted February 13, 2013 Try 3rd gear roll on at middle revs and crack the throttle wide. Try it in both modes. One should feel different to the other. Quote Link to comment Share on other sites More sharing options...
wobblenorbed Posted February 15, 2013 Report Share Posted February 15, 2013 Think of a light swtich, when is turned off the bigger part faces the turned off bit so it almost like rejecting it so on the gas gas if the bigger bit faces the 1 side Map 2 is on or the other way round hope it helps Cheers for that. Quote Link to comment Share on other sites More sharing options...
