j13me Posted February 14, 2013 Author Report Share Posted February 14, 2013 May see you down there then. I used to ride there years back and was amazing! I couldn't do much though. Just had massive balls so went at stuff full speed normally resulting in injuries haha How would I go about checking the feed blocks? Quote Link to comment Share on other sites More sharing options...
j13me Posted February 14, 2013 Author Report Share Posted February 14, 2013 Here is the spark.. Stick it on HD and should see. I'm doubting its strong enough now? Quote Link to comment Share on other sites More sharing options...
j13me Posted February 14, 2013 Author Report Share Posted February 14, 2013 Quote Link to comment Share on other sites More sharing options...
b40rt Posted February 14, 2013 Report Share Posted February 14, 2013 try another plug. Quote Link to comment Share on other sites More sharing options...
j13me Posted February 14, 2013 Author Report Share Posted February 14, 2013 Has a brand new plug tried 3 plugs. All the same? Quote Link to comment Share on other sites More sharing options...
craigh88 Posted February 14, 2013 Report Share Posted February 14, 2013 (edited) Stator? Might be worth getting the specs and checking the resistance. Id check the reeds before this though, as previously said Edited February 14, 2013 by craigh88 Quote Link to comment Share on other sites More sharing options...
j13me Posted February 14, 2013 Author Report Share Posted February 14, 2013 How do I inspect the reeds? I'm new to bike mechanics so any guidance would be great Quote Link to comment Share on other sites More sharing options...
coop650 Posted February 15, 2013 Report Share Posted February 15, 2013 I can't get that video to work, but try this. Put one plug in the bike, put one in the cap to check for spark and kick it. That way you are kicking under compression with a plug in it and the engine is spinning normal speed, not faster as they do with the plug out and no compression. This will tell you what your spark is really doing when you kick. Quote Link to comment Share on other sites More sharing options...
coop650 Posted February 15, 2013 Report Share Posted February 15, 2013 (edited) Also to inspect the reeds, pull the reed block and make sure the reeds are laying flat to the reed cage, check that there are no cracks or holes in the reed petals. If they are raised up or have a crack or hole they must be replaced. Edited February 15, 2013 by coop650 Quote Link to comment Share on other sites More sharing options...
sting32 Posted February 15, 2013 Report Share Posted February 15, 2013 (edited) reedblock is what the rubber boot in front of the carb is connected to with that hoseclamp, just FYI. It has at least one gasket, take care removing, you can make the gasked if you get enough to draw onto sheet of material available an any autoparts stores. Edited February 15, 2013 by sting32 Quote Link to comment Share on other sites More sharing options...
j13me Posted February 15, 2013 Author Report Share Posted February 15, 2013 Thanks coop, the video was with another plug in so that's the speed it kicks over at. Will try find an online guide or video to the reed valves later and see what there like! Think I'm away this weekend so really want her running today! Fingers crossed Quote Link to comment Share on other sites More sharing options...
60north Posted February 15, 2013 Report Share Posted February 15, 2013 hope it starts j13me, and remember when using the choke, dont touch the throttle because it will alter the cold start fueling. good luck Quote Link to comment Share on other sites More sharing options...
shipdamite Posted February 15, 2013 Report Share Posted February 15, 2013 J if it were me I would check out reed block up-turn and dump any fuel that has got into the crank heat up a good plug and maybe a squirt of easy start. failing that....... go for a beer ;-] 1 Quote Link to comment Share on other sites More sharing options...
shipdamite Posted February 15, 2013 Report Share Posted February 15, 2013 or 4 ............... ............ seriously though, It has to be fuel. Quote Link to comment Share on other sites More sharing options...
j13me Posted February 15, 2013 Author Report Share Posted February 15, 2013 Haha cheers guys. Will be home soon and trying again! Offshore this weekend so today is my only day to tinker! Will pull the reed block out and check them out. Knowing my luck the gaskets will crumble and I will be stuffed! Quote Link to comment Share on other sites More sharing options...
