knobby Posted February 14, 2013 Report Share Posted February 14, 2013 2008 beta rev 3 bearings for the swinging arm , £60 surely there is an alternative or somewhere cheaper , would be greatful if somebody could give me some info Quote Link to comment Share on other sites More sharing options...
anotherfive Posted February 14, 2013 Report Share Posted February 14, 2013 for once this is a pretty standard bearing ( 4 ) Take your arm to a bearing dealer, cost me about 15 all in but no bush inserts Quote Link to comment Share on other sites More sharing options...
duffers Posted February 14, 2013 Report Share Posted February 14, 2013 Just search bearing suppliers online and it will give you plenty of companies that can supply the bearings next day from stock, you will need to give them inside diameter, outside diameter and width. You normally get a choice of quality with prices to reflect. The bush inserts can easily be made by local engineering companies, often pays to get a few sets made up at once though. Quote Link to comment Share on other sites More sharing options...
guys Posted February 14, 2013 Report Share Posted February 14, 2013 When you're searching for bearings don't forget that some needle bearings have 1 or 2 small seals built in them. Like this one: Quote Link to comment Share on other sites More sharing options...
644thumper Posted February 14, 2013 Report Share Posted February 14, 2013 (edited) There should be a reference number somewhere on the bearing if it's a standard one,... usually on one end, just like the one above ^^ Get a lip sealed bearing if you can, keeps all the crap out ..... the one above is lip sealed Edited February 14, 2013 by 644thumper 1 Quote Link to comment Share on other sites More sharing options...
knobby Posted February 14, 2013 Author Report Share Posted February 14, 2013 Many thanks for your replies Quote Link to comment Share on other sites More sharing options...
chris morris Posted February 14, 2013 Report Share Posted February 14, 2013 (edited) HK2218-RS SWING ARM you'll have to use your existing bushes cheaper ones http://www.simplybea...oduct_info.html skf ones http://www.simplybea...oduct_info.html also BLRB366748AA SHOCKER HK1216-2RS REAR BRAKE 6004-2RS WHEELS 32004x HEAD STOCK Edited February 14, 2013 by chris morris 1 Quote Link to comment Share on other sites More sharing options...
