Swinging Arm Bearings
knobby
Just search bearing suppliers online and it will give you plenty of companies that can supply the bearings next day from stock, you will need to give them inside diameter, outside diameter and width. You normally get a choice of quality with prices to reflect. The bush inserts can easily be made by local engineering companies, often pays to get a few sets made up at once though.
There should be a reference number somewhere on the bearing if it's a standard one,... usually on one end, just like the one above ^^
Get a lip sealed bearing if you can, keeps all the crap out ..... the one above is lip sealed
Edited by 644thumper
