scot taco Posted February 17, 2013 Report Share Posted February 17, 2013 Is there a good way to clean/flush the mid section on my TY250A ? It seems pretty mucked up and I thought about trying to flush it with diesel fuel.I don,t know if there is any packing material in there that might get ruined by anything I might use to flush it with.If so,then is like a Sherpa exhaust where you have to cut it open to properly do the job? Quote Link to comment Share on other sites More sharing options...
guy53 Posted February 17, 2013 Report Share Posted February 17, 2013 I burn mine : I put a little gas in and light up with a torch, once the fire is started, I leave a bit of oxigene whit a bit of air from the compressor and let burn. If the combustion is right, you can '' follow '' the the red patch all along the exhaust. I have to tell you that it's not the thing to do when a neighbor is out on the patio whith friends, it make a lot of smoke. Another way to do the job is to put the exhaust in a fire and let burn. Guy Quote Link to comment Share on other sites More sharing options...
