Is There Any Long Levers For Sherco?
lewis cosgrove
the s3 ones look short in the pictures but are actually long. i have them fitted on my gas gas and they have a really nice feel to them. plus they look awesome! especially on blue on sherco .
these will also fit
http://www.trialsuk.co.uk/products/ajp-clutch-lever-long
http://www.trialsuk.co.uk/products/ajp-brake-lever-long
The Sherco clutch lever is diffrent than other AJP master cylinders. S3 does make a lever for Sherco. The mounting bolt hole is a liitle offset on the Sherco S3 clutch lever.
The standard AJP lever will work in an bind, but the bolt/pin that pushes on the plunger will be at a bad angle giving a bad feeling at the lever.
Also the S3 levers aren't really any larger than the stock levers. I haven't found any large levers that fit the stock Sherco clutch master cylinder. That's the main reason I swap to a race/enduro master cylinder.
The front brake levers are the same as other AJP.
Does anyone know why sherco have a unique clutch master cyliner, I know the gassers etc have a smaller mineral fluid. I am thinking of changing levers as I have the Ajp genuine medium levers which are o.k exept the are not anodised & I ride without gloves so I end up with black fingers. I suppose any lever will be o.k for me. I only use 1 finger on my controls and have had long and short levers on various bikes in the past and the lever size doesn't matter to me, I just set the bite and reach and I'm good to go. Do the Apico levers fit?
