shyted Posted February 20, 2013 Report Share Posted February 20, 2013 Read quite a few things on this site about the corroding water pump housing . Cut a long story short ,and if you are willing to stop the rot once and for all . Go in the internet and put in camco scientific coatings . They are based in Warrington Cheshire and have loads of solutions to problems . You can have the contact surfaces coated and they'll be no bother ever again . Have had a few things done and they're not cheap but you get what you pay for and the solutions work . Shy . Quote Link to comment Share on other sites More sharing options...
pindie Posted February 20, 2013 Report Share Posted February 20, 2013 How much? Quote Link to comment Share on other sites More sharing options...
shyted Posted February 21, 2013 Author Report Share Posted February 21, 2013 Allot less than a new case from Beta , for a piston crown treated with ceramic £65 ,but you wouldn't need anything that harsh so it will be less . When i get to work i'll check it out and let you know . Otherwise check them out . Ok i understand the do it yourself approach but with a good case ,or new case (and cover and indeed the whole unit ) it's a permanent professional fix . Quote Link to comment Share on other sites More sharing options...
