Montesa200 Help Needed
moocher22
said you would have fun ,,its hard to describe but ill have a go ,, with the selector out in your hand the spring goes on both legs down to the end the legs go either side of a metal tab without crossing each other probably spreading the legs apart , then when you slide it in ( this sounds like its from a porn mag) the long bolt that pertrudes the inner casing fits inbetween the spring so when the shifter is moved up or down the spring returns it to its center position ,, remeber to align the dots up on toothed arm and cog ,, also check clearence on all parts when fitting the circlip on left side also fit a washer taking up any slack ,clip needs to seat well and be tight fit
Thought it was bent,when you say these snap what's the usuall outcome weld another piece on,ps you were right about the fun I would have,thanks for the help this is just the start as after engine it is forks strip and rebuild,another job I have never done--lol
post-18033-0-99223700-1361715031_thumb.jpgpost-18033-0-78742100-1361715090_thumb.jpgHi moocher,
i had exactly the same problem recently. make a small tab from mild steel and weld it on. I welded mine with the selector in place.( Needs a steady hand) make sure you cover the rest of the internals though. think this photo will help. Bit untidy, but theres no way i was gonna get my grinder in there! Don't know why my photos are enormous!?
