lewis_gasgas Posted May 24, 2005 Report Share Posted May 24, 2005 Well i got my oil and stuff and ill do it after ive been away to the lakes on Sat but my dealer said i need 750ml of the stuff and thats fine. Quote Link to comment Share on other sites More sharing options...
brucej Posted May 25, 2005 Report Share Posted May 25, 2005 Lew, I think you will find your 98 is a little different than the picture posted in this thread. On my 98 the sight window is also the filler hole. Quote Link to comment Share on other sites More sharing options...
ba baraccus Posted May 25, 2005 Report Share Posted May 25, 2005 Hmmm are you sure brucej?? Quote Link to comment Share on other sites More sharing options...
lewis_gasgas Posted May 25, 2005 Report Share Posted May 25, 2005 Nope mines exactly the same as the one posted thanks for that BA thats great pic as well. Quote Link to comment Share on other sites More sharing options...
ba baraccus Posted May 25, 2005 Report Share Posted May 25, 2005 No probs buddy Quote Link to comment Share on other sites More sharing options...
brucej Posted May 26, 2005 Report Share Posted May 26, 2005 (edited) After taking a better look at the picture, I will admit it does look like mine. I just assumed it would be different when you showed a different fill hole than what I've been using. I wonder, though, how long it takes you to refill it through that tiny little hole? I've had my bike for 3 years now, change the oil every 2 or 3 rides, never had a problem taking the sight glass out, filling it, and putting it back on. No harder to take out than the sidecover bolt, and gives a nice, big hole to pour the oil in. This is the method recommended by the US importer in the maintenance video I got with the bike, by the way, not something I made up myself. Anyway, you can do it however you like. Edited May 26, 2005 by brucej Quote Link to comment Share on other sites More sharing options...
ba baraccus Posted May 26, 2005 Report Share Posted May 26, 2005 Brucej that photo is actually a little miss leading as it does circle a engine cover bolt. Although it is referring to the filler bung which is just located behind the kickstart. The picture is scanned from the TXT2001 handbook. Quote Link to comment Share on other sites More sharing options...
brucej Posted May 26, 2005 Report Share Posted May 26, 2005 Ah, things become clearer! Maybe we'll get this figured out yet! Just went out to the garage to double check, and there is no bung behind the kickstarter on my 98 tx270. No bolt, or anything else, either, that could possibly be used to put oil in, other than the sight glass. Unless maybe the sidecover bolthole WOULD work?? Gasgas must have changed it up on the newer models. The sight glass does tend to weep oil if you don't use a new sealing washer. A filler hole higher up, out of the oil bath, would be better. Quote Link to comment Share on other sites More sharing options...
ba baraccus Posted May 26, 2005 Report Share Posted May 26, 2005 I doubt the side cover bolt would work, I dont think it goes anywhere? If there is no bung then yeah you must have to use the sight glass! Quote Link to comment Share on other sites More sharing options...
