Scorpa 125 Rear End?
james111089
i know it is possible as i have seen many done before, wether or not it is simply a case of fitting the mudgard and airbox, or the whole subframe, i am not sure, however i do know that the airbox off a 250 doesnt fit properly and you end up with a kink in your rubber tube from the airbox to the carb, this restricts the airflow and reduces performance dramatically.
