axulsuv Posted May 22, 2005 Report Share Posted May 22, 2005 Am I correct in remembering the conversion for N/m to lb/ft... Don't you multiply the nm spec by .738 to get lb/ft, as in torque wrench settings? 50nm x .738 =36.9lb/ft. thanks Glenn Quote Link to comment Share on other sites More sharing options...
stevel Posted May 22, 2005 Report Share Posted May 22, 2005 You're spot on. If you ever need to convert anything try this link http://www.onlineconversion.com Quote Link to comment Share on other sites More sharing options...
axulsuv Posted May 22, 2005 Author Report Share Posted May 22, 2005 Thanks; I'm reassembling my 83 fantic and want to get it as close to right as possable!!! thanks again; Glenn Quote Link to comment Share on other sites More sharing options...
