199B Chain
bondy
Hi Chris
The size of the chain is 520 (5/8 x 1/4).
The lenght of the chain might vary, you have to "check out" the right lenght by controlling the needed slack, there should be a distance of around 10-15mm between chain tensioner and swing arm.
The chain will be deliverd with a chain lock and around 110 - 116 links, you have to cut the not neccesary links with a chain tool (chain link opener).
In some circumstances you might need a half chain link: http://shop.freestyl...?idCategory=447
With best regards
Patrik
Edited by pschrauber
