suzuki250 Posted March 12, 2013 Report Share Posted March 12, 2013 Just tried fitting a set of beamish forks I have lying around on my BSA, but the fork tubes seem to be smaller than 35mm this is stopping me clamping them on the bsa. I’ve measured them and they are 34.87mm which seems to be closer to 1 3/8” did the beamish have odd sized forks? Quote Link to comment Share on other sites More sharing options...
turps Posted March 14, 2013 Report Share Posted March 14, 2013 Either grind or file the gap in the clamps a little bit wider and then when you tighten them they will close further and grip the forks. Quote Link to comment Share on other sites More sharing options...
