davdeborg Posted March 13, 2013 Report Share Posted March 13, 2013 (edited) hi currently running my ty175 at 50-1 on good quality castrol 2t fully synthetic oil just think it smokes a bit to much been reading forums and people are saying anything from 50-1 to 100-1 with a good quality full synthetic 2t oil. any suggestions of a good ratio mix bike only rode off road any help greatly appreciated as neighbours dont like the smoke would it be ok at 70-1 with castrol fully synthetic oil cheers guys Edited March 13, 2013 by davdeborg Quote Link to comment Share on other sites More sharing options...
davdeborg Posted March 13, 2013 Author Report Share Posted March 13, 2013 (edited) the oil im useing is castrol power 1 2t fully synthetic ta Edited March 13, 2013 by davdeborg Quote Link to comment Share on other sites More sharing options...
bestrcpilot Posted March 13, 2013 Report Share Posted March 13, 2013 I run the same oil and also at 50/1 and it does not smoke a lot. Have you clean out the exhust? I found that mine smoked a lot with the old exhust until I burned it out. just a guess Quote Link to comment Share on other sites More sharing options...
davdeborg Posted March 13, 2013 Author Report Share Posted March 13, 2013 no not cleaned it out do you mean whole exhaust or just tail pipe what did you clean it out with ? or how did you clean it out ? thanks Quote Link to comment Share on other sites More sharing options...
nelly1 Posted March 13, 2013 Report Share Posted March 13, 2013 try giving it a bit of a thrashing that should clean it out well enough see if it smokes less after that Quote Link to comment Share on other sites More sharing options...
bestrcpilot Posted March 13, 2013 Report Share Posted March 13, 2013 Hi I mean the whole exhust. i started a fire in a big steel drum and put the exhust in the fire and let it burn overnight. Do not try it this way if it's alum. If you get the exhust good and hot like after a long long ride and it still smokes after you shut the motor off then it's oil build up in the exhust. Quote Link to comment Share on other sites More sharing options...
junker2k Posted March 14, 2013 Report Share Posted March 14, 2013 I run Yamalube 2r at 70-1 with know problems and less smoke. Quote Link to comment Share on other sites More sharing options...
davdeborg Posted March 28, 2013 Author Report Share Posted March 28, 2013 cleaned whole exhaust soaked it for five hours in a red hot caustic bath all clean now no excessive smoke its perrrrrrrrrrrrfect also cleaned the insulation in tail pipe as it was dripping in oil so all sorted cheers Quote Link to comment Share on other sites More sharing options...
