koby Posted March 24, 2013 Author Report Share Posted March 24, 2013 140/1 is recommened for Ossa 2013, isnt it? Quote Link to comment Share on other sites More sharing options...
canada280i Posted March 24, 2013 Report Share Posted March 24, 2013 I got the info direct fom the Canadian importer, it is for all models, not just the 2013, details at this link: http://www.ossacanada.ca/Ossa%20General%20Quick%20Tips%20Guide%20R5.pdf Quote Link to comment Share on other sites More sharing options...
steveo Posted March 24, 2013 Report Share Posted March 24, 2013 Been running Motorex full synthetic at 125;1 in both the 2011 and 2012 280i with no problems. Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 25, 2013 Report Share Posted March 25, 2013 On 3/24/2013 at 10:59 PM, steveo said: Been running Motorex full synthetic at 125;1 in both the 2011 and 2012 280i with no problems. I leave more oil in the measuring cylinder than that !!! 2 Quote Link to comment Share on other sites More sharing options...
borus Posted March 25, 2013 Report Share Posted March 25, 2013 140:1 is fine for trial for the Ossa, use a high quality synth 2T oil. After you warm it up make sure you "rev it out" to clean out any deposits etc from the warm up / choke period. Many riders forget to do this and slowly their exhaust will plug, motor does not breath as it should and you have problems. Hope this helps. Quote Link to comment Share on other sites More sharing options...
b40rt Posted March 25, 2013 Report Share Posted March 25, 2013 (edited) On 3/25/2013 at 12:53 PM, borus said: 140:1 is fine for trial for the Ossa, use a high quality synth 2T oil. After you warm it up make sure you "rev it out" to clean out any deposits etc from the warm up / choke period. Many riders forget to do this and slowly their exhaust will plug, motor does not breath as it should and you have problems. Hope this helps. How did bikes ever run at 25:1 mineral oil ? Edited March 26, 2013 by b40rt Quote Link to comment Share on other sites More sharing options...
koby Posted March 25, 2013 Author Report Share Posted March 25, 2013 (edited) On 3/25/2013 at 12:53 PM, borus said: 140:1 is fine for trial for the Ossa, use a high quality synth 2T oil. After you warm it up make sure you "rev it out" to clean out any deposits etc from the warm up / choke period. Many riders forget to do this and slowly their exhaust will plug, motor does not breath as it should and you have problems. Hope this helps. Ok, I will use 140/1... True is that Ossa with petrol mix 100/1 has problem with choke after a while on little gas... Then I pull full throttle until the engine running smoothly... In fact, life time of spark plug NGK br5es was about 40 hours. Im curious, it will be better with petrol mix 140/1... Edited March 25, 2013 by koby Quote Link to comment Share on other sites More sharing options...
koby Posted March 25, 2013 Author Report Share Posted March 25, 2013 Ossas recommendation is 140/1 ;-) I think my bike is ok, because I know three Ossa bikes and all have problem with totaly black piston and short life time of spark plugs... I think there is behavior. :-( But its off topic. Quote Link to comment Share on other sites More sharing options...
borus Posted March 25, 2013 Report Share Posted March 25, 2013 140:1 is Ossa's recommendation to me. For the fuel, on ECO19 software there is a fuel co-efficient adjustment from 95% to 105%. On ECO17 software set the TPS at 6 to 7 deg - will do the trick. cheers Quote Link to comment Share on other sites More sharing options...
koby Posted March 26, 2013 Author Report Share Posted March 26, 2013 (edited) borus: Ok, but I have map 11, because I have old CDI and map 11 is supposedly the last map for my version CDI . At least my dealer say it... :-/ I must change ECU for be able to record the last software... no? Edited March 26, 2013 by koby Quote Link to comment Share on other sites More sharing options...
canada280i Posted March 26, 2013 Report Share Posted March 26, 2013 Map11 is definitely not the last map available for the old ecu, borus will confirm but I think there is at least a map15 Quote Link to comment Share on other sites More sharing options...
borus Posted March 26, 2013 Report Share Posted March 26, 2013 We have maps for both versions of software since Jan 2013. Neither map 11 or 15 are current. Quote Link to comment Share on other sites More sharing options...
deonattard Posted May 31, 2013 Report Share Posted May 31, 2013 On 3/25/2013 at 10:49 PM, koby said: Ossas recommendation is 140/1 ;-) I think my bike is ok, because I know three Ossa bikes and all have problem with totaly black piston and short life time of spark plugs... I think there is behavior. :-( But its off topic. You guys must have a different version of the manual to me, I have a 2011 and 2012 book and both say 110:1 Quote Link to comment Share on other sites More sharing options...
canada280i Posted May 31, 2013 Report Share Posted May 31, 2013 HI Deon: It's not in the manual, the info came directly from Ossa Canada, there is a document on the Ossa Canada website with the info at this link: http://www.ossacanada.ca/Ossa%20General%20Quick%20Tips%20Guide%20R5.pdf Quote Link to comment Share on other sites More sharing options...
crowley Posted June 3, 2013 Report Share Posted June 3, 2013 Only just read this topic (I don't have an Ossa) but 'Accustafil' is the only packing I'd use in a silencer (Buells and Ducatis blow anything else out). Wrap it snug, but not too tight and hold it in place with a little masking tape which will burn out. Quote Link to comment Share on other sites More sharing options...
