s90gav Posted March 18, 2013 Report Share Posted March 18, 2013 Was on my bike yesterday, and when I got home and unloaded it from the trailer I went to press the brake and the lever just went to the bars, on closer inspection some parts seem to be missing between the lever and the master cylinder, if I was to get this kit in the link is that all I need? Also here's some pics to show what I mean http://www.bvm-parts.co.uk/index.php?route=product/product&path=123_29_116&product_id=151 Thanks Gavin Quote Link to comment Share on other sites More sharing options...
s90gav Posted March 18, 2013 Author Report Share Posted March 18, 2013 Or is it this item I need? Have a feeling it's this. http://bit.ly/Z9BNmJ Quote Link to comment Share on other sites More sharing options...
pindie Posted March 18, 2013 Report Share Posted March 18, 2013 That pin is the bit you need. Once fitted you need to adjust it all so it can't fall out but is not solid. The free play allows the heat expansion required. Quote Link to comment Share on other sites More sharing options...
s90gav Posted March 18, 2013 Author Report Share Posted March 18, 2013 Cheers Think I'll put some locktite on the adjuster on the lever as that was what's rattled in over causing bit to drop out Quote Link to comment Share on other sites More sharing options...
pindie Posted March 19, 2013 Report Share Posted March 19, 2013 The new kit will come with a spring. If this is fitted the bit shouldn't fall out... Quote Link to comment Share on other sites More sharing options...
crazy_dave Posted April 3, 2013 Report Share Posted April 3, 2013 This is kinda funny to me. Sorry for being a newb but, I’ve never seen a setup for the clutch/ front brake masters like the one that’s on my new-to-me Beta rev 270. I thought I was missing some kind of rubber sleeve that would go over the whole spring / pin area, guess not. Should I be able to remove the spring and pin if I push the lever forward, away from the bars? Or should/ can it be adjusted so it’s imposable for it to come out at all? Quote Link to comment Share on other sites More sharing options...
pindie Posted April 4, 2013 Report Share Posted April 4, 2013 You should be able to use the lever span adjuster to lessen the lever swing. This will stop the pin dropping out. Make sure you have a couple of mm play in the master cylinder plunger though. Make sure they are locked tight and check often. Quote Link to comment Share on other sites More sharing options...
