jsp Posted March 20, 2013 Report Share Posted March 20, 2013 (edited) After replacing the rear suspension arms on my 2012 bike due to the main pin snapping, I ordered some new swinging arm bolts as the heads where a bit chewed up, I've just come to replace them and the have both shered off at the end of the threads. I've looked at the shocker and the spring is only hand tight can anymore tell me what the measurement of the spring should be with the shocker off the bike from the factory. Once I get that sorted and tightened up will i be ok to use the Alu swinging arm bolts I've just got or should I look for some steel replacements ? Edited March 20, 2013 by jsp Quote Link to comment Share on other sites More sharing options...
