toxiic_pompey Posted March 24, 2013 Report Share Posted March 24, 2013 When I go out to practice I find that I always seem to give myself an easier route than I would probably find in a competition. I bought 10 red and 10 blue flags so I could mark my own sections. Any advice on what sort of things I should have in the sections? I'm finding it difficult to make my own sections. 1 Quote Link to comment Share on other sites More sharing options...
paul_stuart Posted March 24, 2013 Report Share Posted March 24, 2013 I had the same issue heres how i seemed to sort it Have confidence in your ability and try new things , just like you would in a trial don't be scared to attempt things and HAVE AGO You should not be able to clean the section you make straight away put in things that are difficult but more technical ( tight turns , controlled manoeuvres ) it s not all about the big steps and massive hills As for specifics I personally recommend (alter to meet skill level) : Rock step then about a bike then sharp turn a bike lengths from top Tight turns on hill Drop off then turn Go to nice slippery ground , clay etc Double Tiered steps Wet Streams Hope this has helped Have fun and keep the feet up 1 Quote Link to comment Share on other sites More sharing options...
tltel Posted March 24, 2013 Report Share Posted March 24, 2013 I think we all tend to do that when out practicing, It helps if you can get a mate to set them out for you or with you, Include things that you dont like doing, so that you can practice those bits. I dont like going over logs for some reason and you nearly always get them in our sections down in kent. Turning on cambers is a good one to practice, make your section tight and keep at it, It does make you feel good when you do clean it. Hope that helps TLTEL 1 Quote Link to comment Share on other sites More sharing options...
toxiic_pompey Posted March 24, 2013 Author Report Share Posted March 24, 2013 Thanks for the replies Another other advice I may need? Haha Quote Link to comment Share on other sites More sharing options...
0007 Posted March 25, 2013 Report Share Posted March 25, 2013 Make sections for your buddies to ride, tell yourself it's not for you And then ride them Quote Link to comment Share on other sites More sharing options...
morton Posted March 25, 2013 Report Share Posted March 25, 2013 Practice what you are not good at, not the things you like . Quote Link to comment Share on other sites More sharing options...
pindie Posted March 30, 2013 Report Share Posted March 30, 2013 Always make your turns tighter for practice than you find in a trial. Train hard. Fight easy! 1 Quote Link to comment Share on other sites More sharing options...
jon v8 Posted April 27, 2013 Report Share Posted April 27, 2013 You can practice all you want - the way to get better is simple,just ride more trials. 2 Quote Link to comment Share on other sites More sharing options...
