robee Posted May 25, 2005 Report Share Posted May 25, 2005 I just say: "Excuse me! It must have been the chili." Quote Link to comment Share on other sites More sharing options...
colly Posted May 25, 2005 Report Share Posted May 25, 2005 sounds like the timing to me.a mate had a fantic that sheared a woodruff key and that backfired once, ran for a few seconds and refused to start again.due to the fact the woodruff key is important to the timing it would explain why the bike will not run anymore. just a thought, see if it hepls my old gasser did that to. worth checking Quote Link to comment Share on other sites More sharing options...
james111089 Posted May 25, 2005 Report Share Posted May 25, 2005 since i siad about the plug , my bike wouldnt fire up today tried and tried weak spark and its the plug gone NGK must be lacking in quality lol James Quote Link to comment Share on other sites More sharing options...
steveo Posted May 26, 2005 Report Share Posted May 26, 2005 Good to hear sy250, Yamaha reliability shows again.....All you doubters . a spark plug and the smile returns. Quote Link to comment Share on other sites More sharing options...
sy250 Posted May 26, 2005 Author Report Share Posted May 26, 2005 NGK platinum, job done. Well impressed with scorpa build quality. Quote Link to comment Share on other sites More sharing options...
lastplacebrad Posted May 26, 2005 Report Share Posted May 26, 2005 my old gasser did that to. worth checking Thats fine , but lets not forget we are talkin about a real engine here !! Quote Link to comment Share on other sites More sharing options...
dfwilson Posted May 26, 2005 Report Share Posted May 26, 2005 If it backfires too many times here is what happens. Quote Link to comment Share on other sites More sharing options...
jools Posted May 26, 2005 Report Share Posted May 26, 2005 Quote Link to comment Share on other sites More sharing options...
lastplacebrad Posted May 26, 2005 Report Share Posted May 26, 2005 If it backfires too many times here is what happens. er... hmmm ,ok how can one stop it happening then ? Quote Link to comment Share on other sites More sharing options...
eric23 Posted May 27, 2005 Report Share Posted May 27, 2005 I noticed you got a platinum plug. I thought the iridiuim plug was the hot ticket. Quote Link to comment Share on other sites More sharing options...
sy250 Posted May 27, 2005 Author Report Share Posted May 27, 2005 So did I. Put i am just using what Birkett recommended. Quote Link to comment Share on other sites More sharing options...
bruceinal Posted May 30, 2005 Report Share Posted May 30, 2005 If it backfires too many times here is what happens. (picture of split exhaust) It sure does, as I found out this weekend. Fortunately, I was able to bend it back shut for the day, but it will still ultimately need to be welded. I have found that the backfire happens in two different cases. The first, which is totally avoidable, is if you let off the kill button too soon; before the engine has COMPLETELY stopped. The second is when starting, and it seems that it's most likely to happen if you give it a half-hearted kick, which I usually do since the bike starts so easily. After mine split this weekend, I was careful to give it very solid kick every time, and it didn't do it again. Of course, one afternoon isn't enough time to say for sure that it won't still do it, but at least it might be less often. Quote Link to comment Share on other sites More sharing options...
marky g Posted May 30, 2005 Report Share Posted May 30, 2005 Bought my SY with a split mid box (it had split in the exact same place as the pic before!!), mine was starting to go around the outlet neck too..... had it all welded up...never thought it was down to the missfiring though........valid point I guess. Mine does it now and again, if it does not go second kick it will normally back fire...my guess is unburnt petrol getting in the exhaust system whilst trying to kick it up. Not too much of a problem at the moment though. Quote Link to comment Share on other sites More sharing options...
boofont Posted May 31, 2005 Report Share Posted May 31, 2005 BruceInAl is on the money with his examples of backfires. I use a platinum plug, they're tops and last for ages. Just changed mine after the SSDT and to be honest it could have stayed in longer. Quote Link to comment Share on other sites More sharing options...
boofont Posted May 31, 2005 Report Share Posted May 31, 2005 There's a new one in, just saying that the old one looked ok. Its yours if you want it? Save you a few penny's there John! Quote Link to comment Share on other sites More sharing options...
