Replacement Frame
struttf
struttf
In the first instance i would have concerns of a different type. No frame number and no engine number are a very worrying combination.
Worth a double and treble check that your looking in the right place (headstock for the frame and below the exhaust?? (from memory) for the engine number)
Did the frame that you are replacing have a number?? Often your dealer will stamp a replacement frame and provide you a letter / certificate of some type. I have also seen the old frame headstock cut off and kept for proof of replacement.
Its easy to over-react, but if there are no numbers there are few good reasons.
the replacement frame has no frame no. as the last frame was completely written off and the crankcases were replaced as well with a old set of non matching code that would make it an 05 ( front of casing under exaughst) doesn't realy matter but would be nice to know how to prove it is if someone asked
basicaly everything on the bike has been replaced over the last 2 years
Fraser so long as its the new style frame then it's at least 2011.
2009 / 2010 had different frame
2011 / 2012 / 2013 have a different frame with an extra section of triangular frame at the front of the airbox
