Txt Pro Front Wheel Fitting
mccarro
The fork on my 2008 has a thin insert in the hole the axle goes through on the disc side. The insert sits slightly proud of inside face of the fork. Is this right or should it be flush with the face of the fork?
Is the insert meant to be pushed against the face of the bearing when the axle is tightened ? Mine appears to be seized in the fork.
Any advice welcome
