charlie chitlins Posted July 2, 2013 Report Share Posted July 2, 2013 3 years? That's a blink of an eye for me! Better for balancing on the rear wheel, eh? I don't even know anybody who can do that! 1 Quote Link to comment Share on other sites More sharing options...
luckaz Posted August 24, 2013 Author Report Share Posted August 24, 2013 Wanted to give you an update. The mod did not work. Still stalling. I changed the float height so much that eventually the bike wouldn't start; still stalling. Tried moving to a 50 pilot jet; nope. Any advice? I'm frustrated. Just want to sell the bike now and get rid of this problem. Our local trials mechanic is just as baffled as me. He has same bike and same problem. Thanks Quote Link to comment Share on other sites More sharing options...
copemech Posted August 25, 2013 Report Share Posted August 25, 2013 Luckaz, To be honest, we have no idea your level or ability, just how extreme downhills you are referring to. There are limits it seems on any carb or bike, yet in my opinion the K carb is more susceptible as compared to say a stock Dellorto. Splat Chris would be the uppel level rider with better answers, yet I can tell you from many bikes past, I had to anticipate a fuel surge on big downhills and clean out as necessary. MC Quote Link to comment Share on other sites More sharing options...
luckaz Posted August 25, 2013 Author Report Share Posted August 25, 2013 It has nothing to do with 'extreme downhills'. It will stall going down fire roads or logging roads that a typical truck could drive up. We have loads of steep riding here but it will stall on stuff you could ride a bicycle up. Thanks for any suggestions. Quote Link to comment Share on other sites More sharing options...
charlie chitlins Posted August 25, 2013 Report Share Posted August 25, 2013 I once worked on a Scorpa that did that. I could pick up the rear wheel and it would stall. Faulty carb. Some kind of machining glitch. Quote Link to comment Share on other sites More sharing options...
luckaz Posted August 26, 2013 Author Report Share Posted August 26, 2013 Thanks Charlie, I'm considering a new carb just to see if that could fix the issue. Easy way to sort out the source of the problem too.. If it still happens w a new carb than the carb is unlikely the cause.. Quote Link to comment Share on other sites More sharing options...
copemech Posted August 27, 2013 Report Share Posted August 27, 2013 Other than a few reported issues with setting of the float levels, I cannot recall sig. reports of issues such as yours. There may be a possibility the float is hanging up in the overflow tube that extends up into the bowl. Such radical changes in float height are generally not needed. I pull the overflow tube and BB it off on a K style carb, myself. Splat Chris has some suggestions of that on his website, yet all personal pref. I say all this while still using the Dellorto on my 250, which just works it seems. Nothing special, not as great o power or all that, just works. Call Chris and debate it! He gives sound advise and better experience. Quote Link to comment Share on other sites More sharing options...
luckaz Posted October 9, 2013 Author Report Share Posted October 9, 2013 Just wanted to let anyone who is interested know that increasing the idle speed fixed the problem. Embarrassing to admit and a huge waste of time in retrospect(taking the carb apart ~ 15 times). Simply increasing idle speed fixed it right away. Thanks for all your suggestions. 1 Quote Link to comment Share on other sites More sharing options...
copemech Posted October 9, 2013 Report Share Posted October 9, 2013 Just wanted to let anyone who is interested know that increasing the idle speed fixed the problem. Embarrassing to admit and a huge waste of time in retrospect(taking the carb apart ~ 15 times). Simply increasing idle speed fixed it right away. Thanks for all your suggestions. Good report then, yea, keeping it jacked slightly is good! Regardless of carb, I set mine to where the bike will chug up a slight grade in 2'nd on its own. Ignition timing comes into play as well, specially on some prior year models, as they may kickback stall at low revs if too advanced,usually at the wrong time! Quote Link to comment Share on other sites More sharing options...
cord Posted May 8, 2014 Report Share Posted May 8, 2014 Just to dig out an old thread, i also just upped the idle speed to mask the problem. However after a while the idle on mine also became erratic. It turns out the rubber on the inlet manifold starts to dry and shrink over time, peeling itself of the metal core and reed block. Stripped the inlet manifold and reed block, re-sealed with engine gasket sealant. Back together and it is a revelation! It must have been getting slowly worse and worse and i hadn't really noticed. It's like a new bike, lovely and smooth off the bottom, no hunting, and no stalling on steep descents, even with a very low idle. I think the stalling on steep descents was down to the weight shift of the carb, opening gaps and ruining the mixture. I spoke to Chris at splat shop, and confirmed all the above, apparently he's seen it a few times, and has re-sealed a few inlet manifolds. Wish i'd rung him sooner, bloody top bloke. Quote Link to comment Share on other sites More sharing options...
luckaz Posted May 8, 2014 Author Report Share Posted May 8, 2014 Brilliant Cord, I'll have a look at that area asap. I recall I had to put some tape on the Carb outlet previously as the boot was a bit loose. Maybe there is more going on there that I missed. Thanks Quote Link to comment Share on other sites More sharing options...
tltel Posted May 8, 2014 Report Share Posted May 8, 2014 Charlie.... Just put your tools in your socks. C of G sorted !!!!! TLTEL Quote Link to comment Share on other sites More sharing options...
luckaz Posted May 12, 2014 Author Report Share Posted May 12, 2014 So I took the reeds out and found the gasket material there very slightly crinkled (not cracked) . There was a little discolouration where it looked like gases were escaping or being sucked in. I cleaned everything and sealed it all with a tiny amount of silicone. I rode today and for the first time the bike didn't stall once. Couldn't believe it. Finally found the problem. Thanks Quote Link to comment Share on other sites More sharing options...
cord Posted May 13, 2014 Report Share Posted May 13, 2014 Glad it has sorted it. Quote Link to comment Share on other sites More sharing options...
copemech Posted May 14, 2014 Report Share Posted May 14, 2014 So I took the reeds out and found the gasket material there very slightly crinkled (not cracked) . There was a little discolouration where it looked like gases were escaping or being sucked in. I cleaned everything and sealed it all with a tiny amount of silicone. I rode today and for the first time the bike didn't stall once. Couldn't believe it. Finally found the problem. Thanks Are you referring to the outer(rectangular) reed block sealing surfaces? Quote Link to comment Share on other sites More sharing options...
