Clutch Grinding The Clutch Cover
sjw
Hi I have a gasgas txt pro 2008 can any one help ? I have just fitted a new clutch cover gasket as I had a leak and now the bolts on the clutch basket are grinding at the clutch cover . The gasket is the same thickness and the washer and bearing are on correctly also the washer on the kick start is in place .
Well basically even though I was only replacing the gasket because of a small leak when I put it back together the clutch basket was grinding the clutch case it had moved out buy approximately 3-4 mm I can only images the center nut had worked loose and using he kickstaet to line up the water pump made the basket move so I followed he advice on here and all is well
I also had a small leak on he waterpump brass bush / drain the washer was squashed ,so made one out of a milk carton will order a real one on Monday but does he job !
