Crf205L
triple_x
Hi
Just bought a CRF250L, and WOW!!!!
Value for money,well made and ideal for casual green laneing.
Already taken the firetrap off the airfilter, dropped the front sprocket by 1 tooth and onto the Dyno @ JHS Racing Saturday.
It comes with street legal IRC's that stick like **** to a blanket.
Kind regards
Martin
http://www.google.co...5&tx=131&ty=120
Hope this helps until I can take a pic.
Basically it is a cheaper version of the Skyfall stunt bike the CRF250R.
Keep it pinned in first, second, third and fourth and boy does it fly. Not as quick or as light as a KTM but a lot less to buy and more reliable and it brings a smile by the mile! Sorry!
Even geared down it does 80mph.
Martin
Edited by triple_x
I'd fit an old road tyre if you're going on a Dyno. When sorting the fueling on my Ducati 1198, I went through several (but they were old race slicks that had been heat cycled too many times)
If you're just doing a power run, then your knobblie tyre MAY be ok, but it MAY slip on the roller and give a false reading.
  • 1 month later...
Hi
Dyno results at rear wheel are:-
  • Max power 19bhp @ 8,500 revs
  • Torque 14 ft lbs @ 5.200 revs
Mods so far
  • Remove spark arrestor from airfilter
  • Full Arrows titanium and Aluminium exhaust system including Cat.
  • Rev counter that works from just wrapping a wire 5 times around the plug lead.
  • EBC sintered front pads.
  • Hel braided brake lines.
General thoughts after 800 miles.
  • Quality, good solid build
  • Fuel injection and electric start, ace.
  • Handling on IRC trail tyres, tight holds lines well and really good all rounder.
  • Value for money great.
  • I droppped the front sprocket 1 tooth to 13 but reverted to original to make sure I keep within the NSL's. Could not be faffed to work it out but can get a corrector module if i want. Perhaps!
Use
  • Saturday ride out for breakfast.
  • Observing for the IAM
  • No off road as yet!!
Hope you find this on interest.
Regards
martin
Edited by triple_x
