Where To Find 1994 Gas Gas Fork Bushes
zerorev3rev4
Good luck. My 1992 needs them as well and I was told Gas Gas no longer has them available, for mine at least. Yours has different forks so you may get lucky. Mine are such an odd size I spent days trying to cross-reference a bushing from a different bike and can't find any this size (39mm OD x 36mm ID x 20mm height with 1.5 mm thickness). I ended up having some made from brass. Not ideal but otherwise this bike is junk because the bushings allow so much movement the forks leak and I have no front brake due to that.
