petrg Posted April 14, 2013 Report Share Posted April 14, 2013 As per the title I need to get fluid into my rear brake master cylinder, but as Ossa decided to mount it vertically, it poses a problem, if you just wanted to pop the lid off and top up, just as you would with the Front Master cylinder. Do I need to Use a Syringe and fill from the bleed nipple on the caliper, or is there another way.?? Cheers Quote Link to comment Share on other sites More sharing options...
jsp Posted April 14, 2013 Report Share Posted April 14, 2013 Just unscrew the cylinder from the frame And top it up Quote Link to comment Share on other sites More sharing options...
petrg Posted April 14, 2013 Author Report Share Posted April 14, 2013 Ah haa... Well that's cleared that up. Many thanks Quote Link to comment Share on other sites More sharing options...
jsp Posted April 15, 2013 Report Share Posted April 15, 2013 or theres a small allen headed screw on the side of the cylinder if you can get a syrigine small enough to could us that Quote Link to comment Share on other sites More sharing options...
