mozchops Posted May 26, 2005 Report Share Posted May 26, 2005 (edited) hi people just finished putting in a new clutch pack on my 02 280 pro and when i came to start it there is no engagement of the gears on the kickstart side of things (other words it won't turn over), so took it all apart again and can't see anything a miss. Has anyone any ideas as what could be happening? anyone help or advice would be a great help Thanks in advance mozchops! Edited May 26, 2005 by mozchops Quote Link to comment Share on other sites More sharing options...
windlestone Posted May 26, 2005 Report Share Posted May 26, 2005 (edited) make sure the bolt in the centre of the clutch basket is tight. Edited May 26, 2005 by windlestone Quote Link to comment Share on other sites More sharing options...
spinner Posted May 26, 2005 Report Share Posted May 26, 2005 (edited) Make sure that the looped wire on the kickstarter shaft is pointed at the one oclock position or a the bolt hole for the cover screw. This spring makes the gear pull up when you kick it over. I moved the one on my bike once and it would not kick over! Edited May 26, 2005 by spinner Quote Link to comment Share on other sites More sharing options...
harrytrialsboy Posted May 26, 2005 Report Share Posted May 26, 2005 thanks for all the info lads just another quick question where do i put the oil in i cnt find the fill plug ???????????? thanks again lads Quote Link to comment Share on other sites More sharing options...
jenkinsm Posted May 26, 2005 Report Share Posted May 26, 2005 Its right in front of you!! Its just above where the clutch cable goes into the casing i.e the nipple. It takes a 5mm (i think) allen. It looks alot like the drain plug which you will have taken out the bottom. Quote Link to comment Share on other sites More sharing options...
mozchops Posted May 27, 2005 Author Report Share Posted May 27, 2005 spinner you were right the spring loop over the shaft was not located right, (funny how you can't see the woods for the trees),this website is just the best! Quote Link to comment Share on other sites More sharing options...
