bulla101 Posted April 17, 2013 Report Share Posted April 17, 2013 Hi Guys, Im new to the site and new to Twinshock trials, i bought a 200 last year in reasonable condition, gave it a quick once over, oil change etc and have ridden it since at quite a few local meetings, the bike had its teething issues which i have managed to iron out as i have gone along, with us having a two week break between trials i decided to strip the bike down and have the frame etc painted, i have had the carb ultrasonic cleaned, standard jets put in but i cant find any info on the float hight, can any of you shed any light on this as its the last piece of info i need , oh and i have a trial on Sunday so would like to have this sorted for then, PS: its a standard 25ml carb. Cheers Andy Quote Link to comment Share on other sites More sharing options...
basecampkid Posted April 17, 2013 Report Share Posted April 17, 2013 Hello , the float height should be between 23.5mm and 24.5mm, that is measured from carb body to end of float ,when the carb is laying on a flat surface so that the air box side of the carb is at the bottom, info sourced from official Dellorto manual, hope this helps. 1 Quote Link to comment Share on other sites More sharing options...
rtm Posted April 27, 2013 Report Share Posted April 27, 2013 Can you clarify that a little bit. I have read it a few times and just cannot grasp it. Sorry to be a pain in the a***. Quote Link to comment Share on other sites More sharing options...
