Fantic Muffler Interference Problem.
actwin
My 300 Trial Pro's tire rubs the muffler when the suspension is compressed, is this normal? I can't see where anything is bent, could it be the previous owner had a larger tire on that did this? Once I get her back together I'll see if it still does it. I was thinking maybe this might be a commen problem with this model. Thanks,Scott
It shouldn't hit , Check the mount bushing and cycle it thru full compression without the shocks attached , it may be close and mud.dirt will scratch the silencer ...
Have you ridden it yet ???
keep your feet on the pegs !!
Glenn
