Buying A Ty175
tjp
floppy gear shift action
kickstart lever cracked at knuckle
play in kickstart knuckle
kickstart not returning
kickstart not staying in retracted position
hole in clutch case from kickstart spline clamp screw head
impact holes in magneto cover
frame damage - cracks, bends, twists
rusty fuel tank internals
damaged exhaust header
rust pitted fork tubes
I bought one off ebay and (so far!) have been lucky with it. It's a great newbie ride and doesn't bite.
The gear change has part of its mechanism behind a cover next to the lever. A bit of grease and fiddling sorted it without dismantling the engine.
I understand any kick start related issues are a lot more involved to sort.
There are lots modified in some ways (bits of frame sawn off to save weight etc), so look at lots to see what they are generally like.
Nearly all of them have had the oil pump removed so you run on pre-mix. Not a problem if done properly.
Mine has lights so could even be put on the road.
