Txt 70 2002
malcolm
Hello all,
Can anyone advise how to fit the clutch cover to my sons bike. There is a circlip with a large lug on the kick start mechanism. I am not sure if this has to be located into a recess on the clutch cover or if it has to be in a caertain position prior to fitting the clutch cover. Also does the kick start return spring have to be fitted in a certain way. If so how do you do this. Thanks for all help received.
