kee360 Posted April 20, 2013 Report Share Posted April 20, 2013 Evening chaps just wonted some help went to pull the bike out the shed today and the rear tyre was flat . So I put some air back into it to find the leak with abit of soapy water and found it leaking from the side of the rim the spokes seem fine . I can also see abit of mud between the rim and the tyre .I was thinking of taking the wheel off and then the tyre to clean the rim and hope that stops the leak is it an easy job to do not been riding long and not really down any work on my bike before . Quote Link to comment Share on other sites More sharing options...
thats_a_five Posted April 21, 2013 Report Share Posted April 21, 2013 I assume this is a tubeless tire? The dirt could be causing the leak. Unless you have a good source of high pressure air, I would not suggest trying to take the bead off the rim. My Dunlop takes about 90 psi to get the bead to set. You could let out all the air, then try to pull the tire away from the rim by hand and flush with running water to remove the dirt. If that does not work, you may have to remove the tire, do a thorough cleaning and reinstall. If this is a tube type tire, then you will have to get the tube out and patch it. Good news is that tube type tires are much easier to set the bead. Quote Link to comment Share on other sites More sharing options...
pindie Posted April 21, 2013 Report Share Posted April 21, 2013 How quick does it go down? if its really slow just pump it up high between rides. If the tyres pretty good you could have it re fitted. Quote Link to comment Share on other sites More sharing options...
bruces670 Posted April 30, 2013 Report Share Posted April 30, 2013 Sorry to hijack but I have the same problem it's a new type wheel without the rim tape and keeps going flat the valves fine so I'm guessing its the rim,can you see any problems with using slime? Quote Link to comment Share on other sites More sharing options...
0007 Posted May 1, 2013 Report Share Posted May 1, 2013 Slime seems to do what it's supposed to do but it adds a pound of the snottiest schmeg in the world to your bike and it will gross you out come next tire change I would take a crack at curing the leak first, soap it up and find the leak, pop the bead and reseal All else fails, resort to slime Quote Link to comment Share on other sites More sharing options...
