gazzaecowarrior Posted April 21, 2013 Report Share Posted April 21, 2013 If I ever get the shock off (see previous post) I was just wondering how to remove the rear shock spring. Mines a bit rusty in places and I was going to either paint it or powder coat it. But could somebody explain to me how to remove the spring. Also, will the shock have to be re-gassed afterwards or will it be unaffected by the spring removal. Help would be appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
0007 Posted April 21, 2013 Report Share Posted April 21, 2013 It's pretty straight forward, you spin off the adjusters and the spring comes off But measure your installed spring length first so you can set preload back in the same place 1 Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted April 21, 2013 Author Report Share Posted April 21, 2013 Thanks for that Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted April 22, 2013 Author Report Share Posted April 22, 2013 It's pretty straight forward, you spin off the adjusters and the spring comes off But measure your installed spring length first so you can set preload back in the same place Just been looking at the shock. If you spin off the adjusters they would then have to pass over the larger body of the shock. How do you get this bit off ? Quote Link to comment Share on other sites More sharing options...
0007 Posted April 23, 2013 Report Share Posted April 23, 2013 I think you slacken the adjusters til the spring is slack then the top Clevis just slips off Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted April 24, 2013 Author Report Share Posted April 24, 2013 Thanks for that. The swingsrm end of the shock is seized in the swing arm so i should still be able to get the spring off then Quote Link to comment Share on other sites More sharing options...
