gooseneck Posted April 23, 2013 Report Share Posted April 23, 2013 Any thoughts on what's the Best heat resistant paint to use for painting my twin shocks engine? Also should I be using a primer? Thanks on advance Quote Link to comment Share on other sites More sharing options...
turbo Posted April 23, 2013 Report Share Posted April 23, 2013 recently used PJ1 and was very pleased with the results no primer needed BUT make sure that you follow what is said on the tin . Quote Link to comment Share on other sites More sharing options...
nh014 Posted April 24, 2013 Report Share Posted April 24, 2013 I've painted engines successfully multiple times in 40+ years of trials and never used a heat resistant paint. Quite simply, the engine does not get hot enough to require high temp paint. I typically use a good rattle can brand like Rustoleum in medium gloss black (not satin or gloss) for excellent results. Save the heat resistant paint for the exhaust pipe and muffler. 1 Quote Link to comment Share on other sites More sharing options...
riffraff Posted June 8, 2013 Report Share Posted June 8, 2013 Nh041...is that even on air cooled motors? Barrel and head?. Quote Link to comment Share on other sites More sharing options...
