whisky Posted April 23, 2013 Report Share Posted April 23, 2013 During two recent trials my Evo 290 engine has just died in 4th gear. The first time it happened it was at a two lap event and the engine stopped twice on the same section under medium throttle . Once restarted continued the rest of the event fine although it sounded like lack of fuel. The second time was last weekend when attacking a long muddy section up hill in 4th gear under full throttle. Again once restarted with a little difficulty the bike ran fine for the rest of the event. I have my suspicions that it could be lack of fuel has anyone had the same problem and if so is there a fix? Quote Link to comment Share on other sites More sharing options...
axulsuv Posted April 23, 2013 Report Share Posted April 23, 2013 Tank Vent ? Dirty petcock ? floatbowl vent ? Quote Link to comment Share on other sites More sharing options...
wakka Posted April 23, 2013 Report Share Posted April 23, 2013 Hi First check fuel tank breather check for dry mud inside tube check breathers on carb Cheers wakka nz Quote Link to comment Share on other sites More sharing options...
whisky Posted April 23, 2013 Author Report Share Posted April 23, 2013 Many thanks will check out the breathers and report back. Quote Link to comment Share on other sites More sharing options...
b40rt Posted April 23, 2013 Report Share Posted April 23, 2013 Also check for petrol pipe being nipped somewhere. Quote Link to comment Share on other sites More sharing options...
chuckindenver Posted April 23, 2013 Report Share Posted April 23, 2013 bad gas cap...happened to me...replaced the cap...back in business. Quote Link to comment Share on other sites More sharing options...
pindie Posted April 23, 2013 Report Share Posted April 23, 2013 Could also be your floats are too high/low and the bowl does not have enough fuel to draw on. I have the same issue on my rev 3. I've set the floats so it does not leak but this can mean it dies on long trail type climbs with WOT for a while. I let it die, rest for 30 secs kick and go. Just a little slower! Quote Link to comment Share on other sites More sharing options...
ern Posted April 23, 2013 Report Share Posted April 23, 2013 check your float hight. if you visit www.ssdt.org-downloads they have a full diagram on how to set up, i had the same problem with mine 1 Quote Link to comment Share on other sites More sharing options...
nelly1 Posted April 23, 2013 Report Share Posted April 23, 2013 On 4/23/2013 at 3:29 PM, ern said: check your float hight. if you visit www.ssdt.org-downloads they have a full diagram on how to set up, i had the same problem with mine good advise on very first post Quote Link to comment Share on other sites More sharing options...
