bullfrog Posted May 27, 2005 Report Share Posted May 27, 2005 Sirs: I am now continuing the Quote Link to comment Share on other sites More sharing options...
axulsuv Posted May 29, 2005 Report Share Posted May 29, 2005 Out of my 83 240 pro's owners manual. ' primary drivewith helical gears Z-21/71 ratio 1:3.38 secondary drive with chain 5/8"x 1/4" Z-12/39 ratio 1: 3.35. Mine has a 11 tooth countershaft and 39 rear, and it fairly close ratio thru 6th , which of course is1:0.70 overdrive. I'm changing the final drive on mine down to about 1:4.00 or 1: 4.20. I'm old and slow though!!!... Glenn Quote Link to comment Share on other sites More sharing options...
bullfrog Posted May 31, 2005 Author Report Share Posted May 31, 2005 I am a vintage rider on a vintage scoot, so I tend toward the slow side too! If I might impose upon your willingness to share information just a bit further, how do you "feel" about the "gap" between 1st and 2nd? Would you like 2nd to be "closer" to 1st? Or possibly "farther" from 1st? Or maybe you like it just fine? Thanks. Quote Link to comment Share on other sites More sharing options...
