turbo Posted April 27, 2013 Report Share Posted April 27, 2013 Hi, I have a spare 200 exhaust that would benefit from a good clean out, what is the best method of doing this , does it need splitting apart and re welding? or is there some special substance that can be used, back in the fsie days we used caustic soda from the chemist but not sure if this actualy did any thing ! ! any thoughts on this would be of help ,thanks. Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 27, 2013 Report Share Posted April 27, 2013 If you are talking an all steel pipe, try this. Start at the exhaust inlet with a torch set, just a small amount of flame to get the pipe burning. Flame off and go to straight oxygen, just lightly. The pipe will slowly burn all the through the end. Just try to keep a slow burn going. You can see it`s progress. If pipe starts turning red, slow down with the air. It does produce a lot of smoke, but c.leans it out well. Others nearby will not be impressed. Quote Link to comment Share on other sites More sharing options...
axulsuv Posted April 28, 2013 Report Share Posted April 28, 2013 I've always left them in a solvent tank for a day or two , then done the torch trick ... Much to the dismay of fellow employ's and most service managers ... Glenn The smoke produced is caustic !!! Quote Link to comment Share on other sites More sharing options...
0007 Posted April 28, 2013 Report Share Posted April 28, 2013 I would suggest a spray can of combustion chamber cleaner, soak er down leave overnight and most of it will pour out the end Quote Link to comment Share on other sites More sharing options...
