sykes Posted April 30, 2013 Report Share Posted April 30, 2013 hi anyone know how to adjust the play in the rear brake or these bikes? i had the caliper off and everything is moving ok but the brake is not coming on fully to lock the back wheel. it feel like the foot pedal is bottoming out where the adjuster rod is on the brake pedal. online manual says it should be adjusted by slacking the lock nut and shorten or lenghten the rod, but i cant see how it is adjusted as it just looks like a locknut on a threaded rod, but how do i adjust the rod. its pretty hard to get to also as the diagram shows just adjust the rod but the adjustment end goes ito a rubber cover and then it is some kind of valve that takes the brake fluid clear as mud as i read it back, but if anyone has any ideas on it can you post it up please see link http://www.scorpa.fr...Ride_Racing.pdf cheers.... Quote Link to comment Share on other sites More sharing options...
