Tail Light Bulb
cdubb
Hi,
I was wondering if anyone could give me more specs of the Tail Light Bulb (Part No. 26.21-047) used on a 421-048 style tail light. I currently have a single filament bulb. The only time I can make the bulb light up is when I close the hi-beam switch. I am wondering if it is supposed to be a 2-filament bulb. If possible, can you give me a more commercial part number rather than a Bultaco serial number for the proper bulb.
If the part numbers referenced above are not factory part numbers then reference the Bultaco.com website and service manual for details.
Thanks
The bulb I currently have has one filament thus one contact on the bulb.
As for the light socket, it only has one tab, I believe it is intended for one or two contacts on the bulb, the latter being parallel and both would contact the tab simultaneously. Is that an electrically correct statement?
I must say I am terrible with electrical engineering; I've taken the engineering entry level electrical course 4 times :dunce:.
