monty348 Posted May 5, 2013 Report Share Posted May 5, 2013 Ok, It's my first Fantic. I have it home and need to learn about the bike. The only English language manual I've found is for a 305 and a parts manual in Italian for a 307. Can I use the 305 info for setting timing? "3mm on the piston" Can this be correct? Greg Quote Link to comment Share on other sites More sharing options...
grib Posted May 17, 2013 Report Share Posted May 17, 2013 I have got an Italian handbook for a 307 and the timing is 3mm btdc for that too. There will be timing marks that you can check with a strobe on the flyweel just to make sure. Quote Link to comment Share on other sites More sharing options...
monty348 Posted May 20, 2013 Author Report Share Posted May 20, 2013 Thanks for the confirmation. I'm accustomed to static timing of 1.6 - 1.8mm and 3mm seemed too much. Had the bike out for a test on Saturday. Jetting seemed a bit lean at part throttle. Was a #35 pilot and specs. call for #40 so changed it and will need to test again. So far this bike is fun! Comparing it to my TR-34 it feels a bit larger. Quote Link to comment Share on other sites More sharing options...
