Rear Fender Mount
ridgrunr
I didn't like the screw mounts on my Scorpa rear fender because I was afraid the screws would rip out in a fall. I see one guy is even trying magnets (be interesting to see how that works). Until then, here's a pretty easy fix to replace the screws, that let you use nylon zip ties to hold the rear fender on. I simply took a small "L" bracket I got at the hardware store and mounted it to the current theaded hole. I bent the top around the air filter box to keep it from spinning, then the hole in the fender and the new hole in the brakcet line up so you can use the zip ties. I like breaking the ties a lot better than breaking the fender!
